Subpanel does not respond to user action
I have loaded a vi in a subpanel control.
This seems to work well in the development environment, but when I generate an EXE application the front panel controls don't respond to user.
Can anyone help me ?
Thanks in advance
Paolo
Paolo
(3,002 Views)
Hi, using sub-panel, you call VIs dynamically, so LV does not know which ones to embed in the executable.
Double check if you added these "dynamic VIs" while building the executable.
Let me know!
Ciao. Nicola.
(2,976 Views)
Hi Nicola,
thank you for your answer. Actually the problem was another but I fixed it.
I'm doing some control positions rearranging at program startup, depending on hardware configuration.
I didn't want the user to see controls jumping to new locations, so I managed to run my VI as a hidden
child of another "stub" VI. After UI rearranging, I showed the user front panel and hid the stub VI's front panel.
This technique doesn't work well because subpanels VI don't interact, probably due to how LabView manages
Windows messages. This is true for both development environment and executable. My mistake was to directly
run the main VI (into LV) instead of opening and running the stub VI. Now I'm doing it another way.
Anyway I much appreciated you answer.
Ciao
Paolo
Paolo
(2,958 Views)
