05-07-2010 12:19 PM
05-19-2010 03:18 PM
It's very hard to find a solution with the little information of "..cannot creat subVI out out of this code".
Could you please be a bit more specific, what exactly does not work?
Antoher question, why do you want to create a SubVI out of that?
Christian
05-19-2010 08:27 PM
Your sub-vi is an infinite loop. You have a false wired to the loop stop condition. It will run forever. I think you can just get rid of the loop altogether.
-cb
05-20-2010 02:05 AM
@ 10Degree: In LabVIEW FPGA Programming its common use to let loops run forever in wireing a false constant to the conditional terminal, since you stop the VI either from the Host part or in powering off the FPGA Target.
And now, this is not a reason why you cannot create a SubVI from it.
Christian
05-20-2010 08:48 AM
05-20-2010 12:01 PM
I have used infinite loops in fpga too - just not in a sub-vi. I thought this was a sub-vi we were looking at, in which case, it would be called and then it would hang.
-cb
