Sub-vi pop-up as dialog
Hello All
The attached image of the code of a vi shows a sub-vi (attached and called MovieDialog) inside a case structure true frame. The case structure also contains some code to initiate a player to play a short movie.
The purpose of the sub-vi is to pop-up when the data flow enters the true case and display a short message to the viewer. The pop-up is to remain on screen for 4 seconds, and then close.
This is where I'm having trouble. I have coded some basic vi's to test the operation (placed the sub-vi in a while loop and run it with the sub-vi properties set to open when called etc.) and using a time delay, but it doesn't perform the way intended.
So my question....how can I have the sub-vi (dialog) open up on the main vi FP for four seconds and then disappear (even close the sub-vi) without interreupting the main vi operation.
Any assistance is greatfully accepted.
Thanks in advance
Ray
(3,379 Views)
Maybe something like this. .
(3,367 Views)
Hello Jean-Marc
Thank you for your interest.
I've had a look at your vi, and yes it looks like it is what I'm after.
I can get the vi to operate on its own, but haven't managed to get it successfully working when I modify and inseert into my larger code. It's just a matter of time though.
When I have it working, I will update the post.
Regards
Ray
(3,336 Views)
Get an answer yet?  I just coincidently ended up here....
If not checkout implementing/incorporating "Autoit" for controlling non-Labview windows from labview...pretty cool.  I use it to control several non-labview windows all at the same time from a standalone, labview developed executable.  If you need more info, please advise.
Shannon F
(3,180 Views)
