Structure CASE: Can I use a word of bit to choose a particular case?
I know that I can use "CASE STRUCTURE" in which I can set 2 different situation: TRUE AND FALSE. I know that I can also add other case, but... how can I change boolean value. I know that I can use also integer numbers, but... it's possible to use boolean words? For example save in an array 3 bolean value and if:
CASE 1: 000
CASE 2: 001
CASE 3: 010
ecc. ecc.  It's possible? Can you show with a VI (I have LV8)?
Message Edited by Michelle1892773 on 02-22-2010 02:06 PM
(3,683 Views)
Hi there,
Why not use Boolean array to number?
Hope it helps,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(3,680 Views)
VERY GOOD!!! It's automatic if I connect a word of integer that case structure change TRUE AND FALSE in numbers?
(3,673 Views)
Yes.
It sounds like you are very new to LabVIEW.
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
(3,667 Views)
Accepted by topic author Michelle1892773
Yes, the naming of the cases is based on the data-type of the selector. For more info see this page at the LabVIEW wiki.
If you use a numeric, it's even possible to show the value as a series of bits:
Ton
My LabVIEW Ideas
(3,663 Views)
