Strange lattency while communicating with 2 device by USB
Here are keypoints of my setup:
  • 1st USB port: NI USB-6343
    • 3 analog outputs are emloyed
    • 1 analog input is employed
    • loop_A delay: 100ms
  • 2nd USB port: digital camera
    • input data: 2 consequtive images (180x180 pixels, 2 bytes per pixel)
    • loop delay B: 200ms
    • on each loop iteration of loop_B, 2 images are sent to loop_A (using queue)
Sometimes this functionnality is perurbed by unexplained latency. Here is statistics of loop_A delay (delay is added into listbox if delay is superior to 1 sec).
Other observation: once such lattency happens, the LED "Active" on USB-6343 is almost OFF.
Thanks in advance.
Pavel
(2,398 Views)
Probably cause of such malfunction could by desynchronization of loop_A and loop_B that run in separated VIs.
Anyway how to explain such huge latency ... more than 5 sec, i.e. more than 50 times of the loop delay (100 ms)
(2,382 Views)
Resolved. The problem was low-power USB that powered digital camera.
Once camera put on external Power, the problem disappeared.
One more question before closing this topic: is there some function in LabVIEW for determining whether USB port is powerful or not.
(2,369 Views)
