09-07-2021 05:58 PM
Getting this error killing my LabVIEW FPGA compilation on the cloud compile server:
/opt/apps/NIFPGA/programs/vivado2019_1/bin/loader: line 267: 5614 Killed "$RDI_PROG" "$@"
Parent process (pid 5614) has died. This helper process will now exit
There doesn't seem to be anything online regarding this error. Is this a bug in the compile server or is there something I can do on my end to fix it?
09-07-2021 06:09 PM
Can you try compiling a shipping example? Locally?
09-07-2021 06:12 PM
Hi, yes I've tried... The computer just hangs and freezes -- have to do a manual reboot to get it to restart.
09-07-2021 06:18 PM
That sounds like a really fundamental configuration issue. I'd try a different computer or uninstalling/re-installing everything. Or somehow to roll back.
09-07-2021 06:20 PM
Thanks for the response. I will try that. I also want to try updating Vivado (currently using 2019.1.1_AR73110) but it doesn't seem like that is an option with LabVIEW FPGA...
09-07-2021 06:26 PM
You are not using the NI provided Vivado (Xilinx) compile tools? The one from Xilinx may work but that could be your problem.
09-13-2021 03:08 PM
I am using the NI-provided compiler -- the version that is wrapped in Labview FPGA 2020 is the 2019 Xilinx compiler. I am hoping that this may be fixed in the next release (FPGA 2021).
09-13-2021 03:19 PM
This seems to be a configuration issue. Or am I missing something?
