Strange error from NI FPGA compile server
Getting this error killing my LabVIEW FPGA compilation on the cloud compile server:
/opt/apps/NIFPGA/programs/vivado2019_1/bin/loader: line 267: 5614 Killed "$RDI_PROG" "$@"
Parent process (pid 5614) has died. This helper process will now exit
There doesn't seem to be anything online regarding this error. Is this a bug in the compile server or is there something I can do on my end to fix it?
Message 1 of 8
(2,129 Views)
Can you try compiling a shipping example?  Locally?
ALE Consultants
Message 2 of 8
(2,126 Views)
Hi, yes I've tried... The computer just hangs and freezes -- have to do a manual reboot to get it to restart.
Message 3 of 8
(2,123 Views)
Accepted by itst1357
That sounds like a really fundamental configuration issue.  I'd try a different computer or uninstalling/re-installing everything.  Or somehow to roll back.
ALE Consultants
Message 4 of 8
(2,115 Views)
Thanks for the response. I will try that. I also want to try updating Vivado (currently using 2019.1.1_AR73110) but it doesn't seem like that is an option with LabVIEW FPGA...
Message 5 of 8
(2,110 Views)
You are not using the NI provided Vivado (Xilinx) compile tools?  The one from Xilinx may work but that could be your problem.
See https://www.ni.com/en-us/support/downloads/software-products/download.labview-fpga-compilation-tool....
ALE Consultants
Message 6 of 8
(2,106 Views)
I am using the NI-provided compiler -- the version that is wrapped in Labview FPGA 2020 is the 2019 Xilinx compiler. I am hoping that this may be fixed in the next release (FPGA 2021).
Message 7 of 8
(1,993 Views)
This seems to be a configuration issue.  Or am I missing something?
ALE Consultants
Message 8 of 8
(1,990 Views)
