Storing continuous stream of data
I am currently working on writing a vi that will take 200 hz of data from multiple sensor channels and store the data points
Heres what i have so far. i am using a mqtt server to pull the data from
The "rx value' and 'rx message' are what i need to take and ideally build into a continuously updating array
right now, the data updates as a single string but does not store
(168 Views)
Highlighted
That is a picture of such a time piece of your VI.  It doesn't even show anything related to storing data.
How do you expect us to help you with such little information?
(134 Views)
other information is not necesssary, all that im concerned with is that  string of data
(127 Views)
The other information is necessary as what you've shown does not show any attempt to implement what you want.
Shift register,  Build Array are what you need and you learn about them in the LabVIEW tutorials:
LabVIEW Introduction Course - Three Hours
Learn LabVIEW
(123 Views)
I agree that your question is way too vague to offer help.
@arob wrote:
The "rx value' and 'rx message' are what i need to take ...
Your picture only shows "messageID", "RX value", and "RX topic". "rx message" is nowhere to be seen.
Define "store". Accumulate in memory (and display front panel indicator) until you run out of memory, crashing the computer? Stream to disk?
We cannot help unless you provide significantly more information.
LabVIEW Champion Do more with less code and in less time
(113 Views)
