Stopping output tasks properly before exiting a For-loop
Actually I thought of that but somehow it seemed like a workaround and not a "real" solution. But if it is ok, I quess I'll do that then.
Lastly. do I still need to end the input DAQ Assistant -tasks before exiting the For-loop conditionally in order to be able to still read input data later in the program? Or can I just exit the loop and not worry about it?
Btw. Thanks a lot for your help, I'm still quite a noob with all of this...
Message 11 of 15
(384 Views)
Hi Aleksi,
I don't think you need to stop them explicitely - but it will not hurt…
Why is setting an output to a safe value considered a "workaround and no real solution"? How will you handle any emergency situation?
Message 12 of 15
(379 Views)
I meant the part of force feeding the output with 0. I thought that the output should go to 0 if I just stop the output task but I quess I was wrong?
And finally, this stop-function is not really an "emergency" function but rather in frequent use. This is why I don't want to run into problems (like the DAQ device requiring a boot) caused by not ending the tasks properly.
Edit. Check the picture, Is this close to what you meant with feeding the output with 0 after the loop? Would this work?
Message 13 of 15
(375 Views)
Hi Aleksi,
Why should the output go to zero when you switch off the DAQmx task? All you do is switching off the programming logic used to set those output values, but you don't change any output value!
When you need a certain value on your output signal you have to set it…
Message 14 of 15
(366 Views)
Ok, that clarifies it... 😄
Could you still check the picture in my previous post and tell me your opinion if that would work or not. I still need to be able to read data from the same DAQ device after exiting the loop.
Message 15 of 15
(361 Views)
