Stop a sub VI from main VI
I have an application that command a DAQ via tcp.
In the main loop I wait for instruction (listening for new tcp connection) and, if i read a particular string, I start the acquisition using a sub VI.
If I read another string I need to stop the subVI and return a result.
I'm able to do that, but only with a push button (switch when pressed), and I don't understand why it doesn't work with boolean values (in the pentagon: if I read "OF0" I will stop the program)..
I attach an image of my program.
Thanks to all,
Veronica
(The main VI is a modify of Multiple connections - server.vi example.)
Message 1 of 41
(5,099 Views)
Is there anyone?
Message 2 of 41
(5,052 Views)
Dear Veronica,
Thank you for providing those screenshots of your program.  As a word of advice I wouldn't put while loops or event structures in a sub-vi.  You will run into difficulties such as the ones you describe.  Looking at your code; I think you are making life difficult for yourself with this architecture.
The common use for booleans and event structures are inside a while loop with the boolean control inside the event structure.  If you see Example 1 - RW.vi when the button Generate Data is pressed it returns to it's false state.  Whereas in Example 2 - RW.vi the button has a switch behaviour even though it has a latch mechanical action.
I hope this information is useful.
Kind Regards,
Robert Ward
Applications Engineer, NI
Message 3 of 41
(5,049 Views)
@Rob_Ward wrote:
Dear Veronica,
<snip>
I disagree.  As long as you really understand event structures and while loops, you are actually making life difficult by NOT placing them in sub-VIs.  But perhaps you meant that those particular structures inside a sub-VI should be as independant as possible from events occuring outside of it?  That would make more sense  :).
Bill
CLD
(Mid-Level minion.)
Message 4 of 41
(5,031 Views)
Iwould be in some serious trouble if I couldn't put event structures of while loops in subVIs.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 5 of 41
(5,007 Views)
Thanks for replies.
I can't open these examples because I have labview 2010.
A practical idea? I hope that what I want to do is possible, because this is a little part of a big project and I hope that I will not have to change everything!
Message 6 of 41
(4,983 Views)
Who said me that is possible, can explain me how?? Please!!
Message 7 of 41
(4,936 Views)
Anyone that can help me??? PLEASE!!
I don't understand why I can stop a while into a subVI with a button (and references) and not with a variable!
I wait for an expert Smiley Sad
Message 8 of 41
(4,871 Views)
I think you will find the tutorials on state machines fascinating reading.  😉
Bill
CLD
(Mid-Level minion.)
Message 9 of 41
(4,842 Views)
You may want to look at Ben's post here too.
Message 10 of 41
(4,826 Views)
