11-26-2012 11:30 AM
Hello everyone,
I would someone to share with me an example using Labview, where some process has been designed using the "state space design method using pole placement". I do not wish for the use of "Mathscript" in it.
Just a simple example using state space with pole placement.
Thanks in advance
Solved! Go to Solution.
11-27-2012 09:48 AM
Have you checked the shipping examples from the Control Design and Simulation Module?
There is this basic example:
examples\Control and Simulation\Control Design\State-Space Synthesis\CDEx Pole-placement.vi
Or as part of a demonstration:
examples\Control and Simulation\Case Studies\Mechatronics\DC Motor\CDEx DC Motor with State-Space.vi
examples\Control and Simulation\Case Studies\Mechatronics\Pendubot\Pendubot.vi
Also, if you browse around, you could see other examples that shows LQG and other control techniques.
