Yes - I agree with GerdW that the myRIO is a great way to get started with cRIO & RT/FPGA programming. It's very easy to set up and use.
I recently used one for a personal project - making a giant version of Tetris! (https://decibel.ni.com/content/docs/DOC-35435)
I can also recommend the eval kit - it comes with a single board RIO an addon board that contains lots of useful things for starting out with RT/FPGA programming (an LCD display, analogue input/outputs that are linked, some push-buttons etc.). I currently have one on my desk at work as we've been doing some stuff recently with LCD displays. They also have onboard CAN (e.g. automotive) so if you're interested in doing anything with that then I don't think you can do that with the myRIO.
If you can't get the myRIO cheaply enough (because you're not a student - but it's worth talking to NI anyway) then the eval kit is a bit more representative of what it's like to use a cRIO and you can get further with it without needing any additional hardware.
(blog)
