Starting and Running a VI from another computer
Dear All,
I have made a laser microscope labview module that controls a motion stage on one computer and controls and image acquisition system on the other computer. The two computers are connected to WAN via a same router. I am able to ping to each of them via the other. My module runs a user-friendly labview VI on the image acquisition computer that sends updated G-Code files to the motion stage computer which is running an automated VI that receives the G-Code files and sends them automatically to the motion stage. This allows total control of the system via just one computer (image acquisition one). Furthermore, i want to start, run and close the automated VI running on the motion stage computer via the user-friendly VI running on the image acquisition computer. I did some research and found out how to use Active-X and Automation start for this but in my case, it is a VI not an executable. Please let me know if anyone has any suggestions.
I do have a full developmental system from labview but could not locate the application builder so i can make an executable from my VIs.
Any help will be highly appreciated,
Muttee Sheikh
Photonics Research Group,
Dept. of Electrical and Computer Engineering,
University of Toronto,
Canada
(3,352 Views)
I think you would want to use VI server to launch the VI on the other computer.  Here is a link to a message thread discussing the same thing.  One message in that thread had a link to a tutorial.
(3,340 Views)
I tried this method, However it only works if LabVIEW is already running, otherwise it gives me a timeout error....
(3,304 Views)
Then you'll just have to make sure that Labview is running on the remote computer. Smiley Wink
If necessary, put it in the startup folder.
(3,298 Views)
Will it work if I use Active X Automation Open to start Labview library on the remote machine? and then run the VI?
- Thanks again
(3,293 Views)
