08-23-2006 03:06 PM
08-23-2006 03:41 PM
08-23-2006 03:56 PM
08-23-2006 05:14 PM
1. Ray:
No, those are different Apps. One does some electrical Measurements using a PCIe 6259 with DAQmx 8.0, the other one a AOI App using IMAQ 3.5.1 and IMAQ for IEEE 2.0.2. They could both also run as stand alone Apps. Both are using events a lot of sub VIs and standart functions from vi.lib. The VIs I want to call through the VI Server are the Top-Level VIs of those Apps. I only want to start them on the same Windows PID. Thats why I need the loader otherwise the Apps could be started through the Windows Autostart.
For understanding: I have created an exe for each App and one for the loader. The loader is started and calls the top level Vi within each exe.
2. Matt
They did not need to be included because they each has her own exe so they are the start up VI in their own exe.
Thank you for your quick reply
Peter
08-24-2006 02:41 AM
Hi
Are all supporting vi's where they should be on the development machine. LabVIEW will go looking for "misplaced" vi's but the run-time engine will not. "Vi not executable" is generally reported if a component (sub vi) of a top level vi cannot be found by the RTE
Hope this helps
Chris R
