If you start the second VI from within a loop of the first, then that loop
will not proceed to the next iteration until the second VI finishes. If you
simply want both VIs to start running at the same time, you can put the
second VI outside the loop in your first VI.
Alternatively, you can use VI server to load the VI into memory, open its
front panel and run it at an arbitrary time after the first VI starts, but
the first method is simpler if you don't need the extra flexibility.
Martin Eis wrote in message
news:3A7E77AA.7438D07C@bmw.de...
> Hi everybody,
> I want to start a VI so that the original VI keeps running! If I use a
> Sub VI the Main VI waits until the SubVI has finished. I can start the
> second VI manually so that both VIs r
un simultaniously. How can I start
> the second VI from the first???
