Start of one VI simultaneously for two times
Help me please!
I have one VI, and I want to run it for two times simultaneously (with different conditions)...
If I bulid "exe", only one VI is started, and another start only when first is closed...
How I can make it?
LabView 6.0, Win 98
Thanks!
(2,530 Views)
If you're refering to a subVI, you should set to be reentrant in the File>>VI Properties>>Execution page.
You should consider the changes in functionality. You can find more about this in the LV user manual.
If you want the main VI to run twice, edit its INI file and add the line
AllowMultipleInstances=True
Although I'm not sure this will work for 6.0.
At most, you should be able to make a copy of the EXE and run it independently.
___________________
Try to take over the world!
(2,531 Views)
@tst wrote:
If you want the main VI to run twice, edit its INI file and add the line AllowMultipleInstances=True
The INI file line AllowMultipleInstances=True does not work in LV6.0 ... only works in LV6.1 up.
Fading out. " ... J. Arthur Rank on gong."
(2,517 Views)
