Stacked waveform chart using waveform data type
Hi All,
Does anyone know if you can plot multiple waveforms (for the sake of argument let's say 2) on the same waveform chart and stack the plots?
The only information in the documentation I can find about plotting multiple waveform data type signals on a single chart says to build both waveforms into a 1D array and plot that on the chart. When I try that I get 2 overlayed plots, regardless of if I select overlay or stack plots.
The reason I'd like to do this is to display a stacked chart with a meaningful timestamp. I can get my signals to display on a stacked chart by bundling the signals, but then the x-axis displays the sample count rather than the time. I can set it to look like it's displaying time, but it actually just converts the sample count into a timestamp, so every 60 samples it thinks it a minute.
I figured waveforms would mitigate that problem since they have time data built in, but it doesn't seem to work.
I've attached a VI that demonstrates my problem and some screen caps to show what I'm looking at on my end.
Thanks in advance
(5,872 Views)
Accepted by Roberteh
There is a trick to it. You have to start with overlay, then change the legend to as many "stacks" you want and then set to stacked. It is better explained in the attached VI.
Certified LabVIEW Architect
(5,819 Views)
You are not updating the T0.
Instead of build an array of the data, just throw the new update in a WF that has a new T0.
Ben
(5,817 Views)
Thank you! That did it
(5,805 Views)
Could you upload the same vi in 2015 version ?
Thank you,
Rolando
____________
(5,136 Views)
