01-14-2016 04:14 PM
I have a stacked plot which I house in a tab control which is set to auto-size OFF. I do this to prevent the legend from exceeding the height of the tab control when I add many signals, then I set the num rows property to a lower number to make the legend appear to fit.
When I do this during run time, the vertical scrollbar on the legend becomes unresponsive. When the VI is stopped, the scrollbar becomes active again.
Why?
Is there a better way to constrain the legend size?
XL600
01-14-2016 10:24 PM
01-15-2016 08:56 AM
Wonderful....
I did notice that my CPU% was at 15% (LabView.exe). After editing the VI in an area that wasn't even running (Error case that has yet to occur), the CPU went down to 1-2% and the control started responding. Leaving it running overnight, the CPU went up to 7% with no change in the data I/O. How I long for the predictability of the RT code on my PXIe system!
01-15-2016 09:17 AM
01-15-2016 09:24 AM
I am in fact using the tab simply to select. I have a set of 10 stacked charts, a tab with some text talking about not being configured yet, and another tab with an expanded chart. The selection occurs between the textual tab, the expanded tab, and an automatically chosen stacked chart tab. All other tabs are disabled until a reconfiguration occurs requiring one of them.
The selection is automatic so I hide the tabs themselves from the user and only move between them based on specific events.
Can subpanels be used in the same way (Lying on top of one another)?
