Square wave and trigger signal generation in NI PXIe 6738 card
Hi All,
I am using NI PXIe 1062Q chassis and NI PXIe 6738 analog card.
For my application I would like to generate-
1. A square wave, low voltage=0 volt and high voltage=5 volt.
2. Trigger output from this card, so that I can synchronize a output signal (say at port AO0) with the time base of the trigger in the oscilloscope?
Theatom
(1,202 Views)
Yes, definitely possible.
And your question is?
Santhosh
Soliton Technologies
(1,196 Views)
Hi Santhosh,
Thanks for your reply. My apology, I didn't post the questions properly.
My questions are-
1. how can I generate a square voltage pulse ( with some time duration) at some output port?
 2. how can I get a trigger signal from the card?
For example, from a signal generator (or function generator) we get a signal output and a trigger signal ( which helps to trigger in an oscilloscope).
I would like to get a similar kind of operation from this specific card.
(1,187 Views)
