10-03-2019 10:20 AM
Would anyone be able to provide me with code to generate a continuous analogue square pulse wave (pulse duration 20ms, frequency (0-5Hz) for a USB 6008?
Would be greatly appreciated.
10-03-2019 10:56 AM
Have you looked at the DAQmx samples that shipped with LabVIEW? You should find one there called Voltage - Continuous Output. Maybe this works with your device, I'm not sure.
10-03-2019 11:05 AM
Thank you this is helpful. I keep getting the following error related to my clock/timing though. Do you know how I can fix this?
10-03-2019 11:12 AM
I can't read it. Picture is too small.
10-03-2019 11:13 AM
Apologies, here you go
10-03-2019 11:31 AM
It means your device doesn't have an onboard clock. It only supports software timed output.
