Source Control on LabVIEW???
Highlighted
How can we control on the version of VI? For instance: we have "FileName.vi" version 3 and we want use "FileName.vi" with version 1 or 2.1. So how can we get that version for "FileName.vi"? And I've received error msg when go to Tools - Source Code Control and the msg is as attachment.
Please help
Thanks alot
(1,049 Views)
Highlighted
This is definitely something you need to take up with NI support. Go to http://ni.com/ask to get started.
Good luck
(1,049 Views)
Highlighted
If the SCC Administrator has enabled backups, then you can retrieve previous versions of a VI by going to Source Code Control >> Advanced >> View File History or View System History. Page 11-26 of the Professional
G Manual has some more info on this:
http://digital.ni.com/manuals.nsf/websearch/57CC60D27B73A6FB8625665E00635940?OpenDocument&node=132100_US
I looked at the screen shots you sent and they reference the 'provider dir' and 'working dir'. Have you gone through Source Code Control >> Administration... to configure the SCC system?
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(1,049 Views)
