Some problem with setup of GPIB?
Hi all,
when I am set up the GPIB I found some problem:
1, Just after I hit the comunicate with the Instrument button, I can send, write the strings
 to the instrument and then can read the strings from the instrument. But after a little long time,
the comunication will stop and I have to re hit the comunicate with the instrument button again.
what is the problem?
2, what is the difference between the GPIB address and instrument address?
(2,423 Views)
To your questions:
  1. You didn't provide enough information. What instrument are you using? Are you using your own VIs? Are you using a driver? If so, where did you get this driver? Is it a native LabVIEW driver? Is it an IVI driver?
  2. None.
(2,412 Views)
