10-31-2005 09:08 AM
11-03-2005 06:09 AM
Hi Kevin,
Which version of labview are you using?
Could you please post the VI's that aren't responding?
I want to try and recreate your problem in order to find you a solution
Emma R
NIUK & Ireland
11-04-2005 03:26 AM
EmmaR
I am using Labview 6.1
11-04-2005 08:10 AM
Hi Kevin,
I am further investiagting your probelm and nee to know what version of visa are you using?
Emma R
NIUK & Ireland
11-08-2005 04:03 AM
Emma R
I do not known which version of visa I am using. I am using the vis in the serial folder in the instrument i/o folder on the function pallette. Placing the vis is not a problem , it is when I place a visa resource on the front panel, or a visa constant on the diagram that crashes Labview.
regards
Kevin Dyke
11-08-2005 04:23 AM
11-08-2005 04:26 AM
Hello Kevin,
you can find the used VISA version in the Measurement and Automation Explorer under Software-->NI-VISA. The current version of NI-VISA is 3.4.1. If your version is a much older version download the current version and update NI-VISA. Maybe it helps.
Regards ThomasD
11-08-2005 05:13 AM
The latest version will not install.
The program setup.exe returns the error message:"The instruction at "0x%08lx" referenced memory at "0x%08lx". The memory could not be "%s."
regards
Kevin
08-29-2006 08:42 AM
