11-02-2009 06:20 AM
11-02-2009 07:36 AM
How are you communicating with the Chelsea dielectric interface?
- serial
- GPIB
- Ethernet
- parallel
- other?
11-02-2009 07:59 AM
11-02-2009 09:26 AM
Do you have Measurement & Automation Explorer (MAX) installed?
And
Do you have the programmer's guide for the Chelsea Dielectric Interface?
If so, open MAX, under devices find the GPIB device that you have installed. Make sure it is connected to the instrument and try to send a manual command to the instrument. *IDN is a typical command. That would be the first step.
11-02-2009 10:15 AM
11-02-2009 12:01 PM
Sounds like a timeout error.
Here are things to consider:
If you don't have the proper termination character at the end of your commands (*IDN? included) then you will get a timeout error.
You might want to contact Chelsea to see what the termination character is for your device and to get the Programmer's Guide. You might even try searching the Internet. I did a quick search on the NI site for any drivers and did not find any. It does not mean that there are none, I simply searched for Chelsea and did not find anything. Contact the manufacturer to either drivers or the programmer's guide, otherwise it will be difficult to implement anything.
03-27-2017 02:35 PM
Hi ziedelfahem!
I also to need development a tool for control of the Solartron 1260 and interface 1296, but I don't find the correct information about how I can setup the interface, and I don't have no answers from support.
Do you have some information, maybe programing manual for the interface ?
