01-15-2017 10:46 PM
The main purpose of this program is to simulate night and day. In the day, there is sunlight and there's no need for a light to light up the room. In the night, the solar energy that was collected in the day will power up the LED. How do I simulate charging up a capacitor with solar energy collected in the day and also simulate the capacitor discharging voltage to light up LED. I have a solar panel, led, NI myDAQ. My prog is attached.
01-16-2017 01:54 AM
Hi noob,
As an engineer you should know how to get the knowledge you need to solve a task…
General rule: a capacitor is described by C=Q/U. Q is I*t…
It's just a bunch of ExpressVIs… 😄
Do you want to simulate all this or do you want to monitor a real circuit?
01-16-2017 03:06 AM
i would want to simulate
01-16-2017 03:08 AM
01-16-2017 09:51 AM - edited 01-16-2017 09:58 AM
Hmm.... How long do you think a capacitor is going to provide energy once you stop charging it? Unless it is a very large capacitor, not very long.
Consider charging a battery like a solar installation would do in the real world, and if you want to get an A make your charger maximum power point tracking.
Also it is often overlooked in solar simulations that during times like dawn and dusk when the panel is lit but not directly illuminated its voltage will be very near VOC, but available current will be very low. Your simulation needs to do that and your circuit needs to be able to withstand that high static voltage, specially in the case of series arrays.
