08-15-2022 08:57 AM - edited 08-15-2022 09:54 AM
Hello everybody 🙂
I'm writing here for the first time and hopefully I can cleary describe my problem.
I'm working on a LabVIEW project with cRIO-9014 in Scan Mode and because of compatibility issues, I got to use LabVIEW 2018 provided on an external USB from my university.
My problem shortly is when I try to deploy my target NI 9512 through "Interactive Test Panel" I get the error:
"LabVIEW: (Hex 0x80DF001E) The deployment plug-in for this item cannot be found. Verify the proper software is installed". which led me to check the software in NI MAX, here I found out that the SoftMotion Module which is needed for NI 9512 is not detected in MAX although it was installed. I tried to reinstall the module but nothing has changed.
previously on my project I used NI 9237 and it has worked. I'm mentioning it so you can know downloading the RT-modules, the other tools and the connection was done correctly.
I hope I can get a solution and thank you in advance.
08-15-2022 03:37 PM
NI stopped supporting SoftMotion in June of 2021 (if you do a Web search for NI SoftMotion, you can find links to NI that discuss the final releases). That being said, LabVIEW 2018 and 2019 should work ...
08-15-2022 03:40 PM
Hi Bob thanks for your reply….
exactly! I‘m using LabVIEW 2018 and SoftMotion 2018 as well but I still have this issue.
