Snap to closest graph point
I have an xy graph with multiple points. The graph is controlled by a mouse down event, when the user clicks on the graph it draws a red circle at the click point. My question is how I would get this to snap to the nearest point?
I have not lost my mind, it's backed up on a disk somewhere
Message 1 of 16
(4,918 Views)
Hi Paul,
I would look for the nearest plot data using Pythagoras formula c²=b²+a²…
Message 2 of 16
(4,916 Views)
What is the datatype of the xy graph? If you use complex numbers (recommended!), convert the click point to a complex point in the data scale, subtract it from the complex array of points, take the absolute value, and use array min&max. The index of the min is the index of the closest point.
Can you attach your VI?
Message 3 of 16
(4,912 Views)
Please see my attached VI
Message 4 of 16
(4,906 Views)
That's just a subVI, there is no xy graph. Also your subVI is missing.
Message 5 of 16
(4,901 Views)
Message 6 of 16
(4,898 Views)
Here's what I had in mind.
(just showing how to find the closest point. Now simply tranform the value back to pixel coordinates and draw the circle. Not shown.)
Message 7 of 16
(4,892 Views)
Sorry about that please see attached the updated VI
Message 8 of 16
(4,887 Views)
You shold be able to use my code with minimal changes. As I said, simply transform the position of the closest point back to pixels and draw the circle.
Message 9 of 16
(4,880 Views)
I have tried implementing your method but I am not having much luck?
Message 10 of 16
(4,875 Views)
