06-24-2015 03:49 PM
Hi. I am looking for suggestions on how to smooth XY Data that looks like the attached, a closed curve. The Filter vis I have looked at all use X but not X and Y.
Thanks.
Solved! Go to Solution.
06-29-2015 10:06 PM
Have you tried either:
a) using B-Spline Fit?, or
b) smoothing X and Y independently and recombining to give your smooth curve?
You may want to duplicate your data in the fit so that you get a more continuous curve at the end-points. Here's a quick, rough example:
07-06-2015 01:51 PM
That worked. Thank you!
