Smaller Version of Variant to Data
Hi, did anyone create a smaller icon version of LabVIEW's Variant to Data ?
I think it takes way too much space.
Actor Framework
Message 1 of 10
(2,141 Views)
You can do it yourself if you make a *.VIM file and put nothing but the "Variant to Data" VI in there, then make the icon smaller than the standard 32x32 and select a connection pane that works with your smaller icon.  Look up "Malleable VIs" or VIMs if you don't know what I mean by that.
It's not that big of an icon though to worry that much about reducing it, and VIM's aren't perfect.  It may create more problems that it solves.
Message 2 of 10
(2,120 Views)
I like the size because the input is perfectly aligned with the vast majority of the connector panes of anything I wire to it.
Bill
CLD
(Mid-Level minion.)
Message 3 of 10
(2,109 Views)
Accepted by topic author Quiztus2
Message 4 of 10
(2,046 Views)
This is so nice, I thought I would need a Polymorphic SubVI for alle the different possible type inputs. Your version is so much better.
Actor Framework
Message 5 of 10
(2,034 Views)
Just remember that VIMs have their own set of problems.  Just make sure you're not causing more issues than you're solving.  A cosmetic fix just isn't worth creating potential pitfalls in your code.
Bill
CLD
(Mid-Level minion.)
Message 6 of 10
(2,014 Views)
Gee, I was being sarcastic, making the icon as small as I could.
Message 7 of 10
(2,007 Views)
Sarcastic only about the size or also about using .vim here?
Actor Framework
Message 8 of 10
(1,985 Views)
Just the size.  I don't have a problem with malleable VIs (though they can be quirky at times).
Message 9 of 10
(1,949 Views)
That's what I mean.  Is this "quirkiness" worth the cosmetic fix?
Bill
CLD
(Mid-Level minion.)
Message 10 of 10
(1,931 Views)
