09-14-2009 09:01 AM - edited 09-14-2009 09:07 AM
Here's a screenshot of the CPU usage we see during deployment.
As a side note, the second tab "VIs" on the RT System Manager has "Track VI States" unchecked. As a second side note, the "t=" markers were added to the screenshot using a paint program (So don't take a ruler to your screen and try to make exact t axis measurements!).
Jack
09-14-2009 09:11 AM
10-08-2009 12:22 AM
Hi we are having the same problem using a Desktop Dell PC since upgrading to RT 9.0 from 8.6.1. I see that this thread has had little activity since 9/14, does this mean that a solution is available or the opposite?
We are finding the exact same behaviour:
1) Click the Run arrow on the front panel of the vi targeted to the PC running LabVIEW RT 9.0.
2) Watch the vi's being downloaded to the target (takes a couple of seconds)
3) Wait in amusement as nothing happens for 30 seconds ('nothing' means that the vi doesn't execute even though the 'stop' button is active on the FP). I know that it isn't just the front panel that isn't responsive as I can watch the CPU activity on the RT screen and there is no activity assigned to Timed Loops during these 30 seconds (all our code is in timed loops).
4) Executing starts after 30 seconds delay.
5) Stop and start it again without changing any code and this delay doesn't occur.
6) It also happens when a startup exe is created and it tries to run at start-up.
We have also found that this delay doesn't happen for small applications or when using 8.6.1.
Any help will be appreciated.
10-08-2009 08:08 AM
10-08-2009 01:22 PM
I checked on CAR 176549's status. It looks like R&D is testing a possible fix. Depending on how the tests go, I wouldn't be surprised if there is a solution soon.
Kristen H.
10-08-2009 01:22 PM
Even though there is no solution posted yet, just having found this thread has saved us a lot of time in that we didn't have to rip into our own code to find the cause.
Let's hope there is some light soon.
Cheers.
10-09-2009 07:29 AM
Hello everybody,
I would like to report the same problem with one exception. I am using the PXI 8196 as HW platform for running the RT code. All other symptoms are pretty much the same...long hang up time after successful completion; 50% of CPU usage on my laptop during the hang up time, which drops down after it passes away and I am finally able to manipulate the front panel of the vi. Is there any solution?
Thank you,
Straki
10-09-2009 08:17 AM
05-14-2010 03:14 PM
Still having the same problem here. Nearly identical to what the original authors posted.
Ken
05-14-2010 03:36 PM
