Slider Disabled property not being read?
Hi Darin,
Yes, I was already aware of what you pointed out, and I have tried the same trick (looking at click position), but if my displayed value is in close proximity to a threshold, there are still instances where the displayed value gets moved rather than the threshold. I have not yet been able to overcome this problem. I hope that I can, because our customer really liked the pointers for setting thresholds.
Message 11 of 30
(2,162 Views)
Funny I have used this a few times and it works quite well.  I assumed you shrank and moved the "invisible" pointer to a far-off location, greatly reduces the chances of accidentally hitting it.  Just coloring it transparent leaves a relatively large strike zone. If you want it to be zero chance just put a transparent picture or something else over the top, or use the Mouse Down? filter event and toss out all clicks not in the 'MasterRect'.  This Rect will only include the slide area, you may need to pad if the threshold pointers extend a bit above that.  If you then put the invisible slider below the slide it is easy to toss the stray clicks.
In vi.lib\picture\PictureSupport.llb there is a VI called PointInRect.vi which does the job for you.
Message 12 of 30
(2,153 Views)
Darin,
We may have a disconnect as far as what I'm trying to do. If I move the 'invisible' pointer to a far-off location, the value goes along with it. The 'invisible' pointer is associated with the actual value I'm showing in the slider area. For instance, when the battery voltage (shown by the slider with the invisible pointer) reaches a threshold value, the threshold value is directly overlaid with the voltage value, and when I try to pick the pointer for the threshold I get the voltage slider instead.
If you have a working example of a slider that gets around this problem, I'd love to give it a try.
Message 13 of 30
(2,148 Views)
Here is a very quick example.  I left the display pointer colored white so you can see where the dot moves.
Message 14 of 30
(2,145 Views)
Thanks for that, Darin - you've given me some new ideas. I'll need to make a custom control and move the voltage pointer down by the labels and make it invisible. Between that and some coordinate filtering, I think I can build a useable workaround.
Message 15 of 30
(2,141 Views)
Darin,
Where the heck is the MasterRect property?  I can't seem to find it in the property list.
Message 16 of 30
(2,139 Views)
You need to enable scripting to see it.
Message 17 of 30
(2,133 Views)
Aah... Thank you.
If I discard all mouse clicks with a vertical position greater than MasterRect.Top, I can limit the moving the threshold pointer to only clicking and dragging on it.  Clicking in the slider area has no effect. This will work great now with the Silver control! Thanks for your help.
Message 18 of 30
(2,131 Views)
I figured I'd share what I ended up with. This will work well for me.  The 'filled value' slider is the first slider, and its pointer is invisible and moved below the slider area.  The next two sliders are the max/min sliders (interchangeable). I throw out all mouse down events that are in or below the bar area, so that only pointer grabs are active.
Attached VI is in LabVIEW 2010.
Message 19 of 30
(2,121 Views)
I just found a problem with what I posted if you closely stack the controls vertically. The 'filled value' slider's pointer should really be located within the slider area (and made transparent), not below it, so that there is no possibility of a control placed directly below another one to grab the invisible pointer.
Message 20 of 30
(2,119 Views)
