08-31-2011 07:07 AM
What could cause the exlusion of the file from being mass compiled?
CompileFile: skipping C:\Program Files\National Instruments\LabVIEW 8.6\instr.lib\Temptronic TP04300\Examples\TP04300 Poll Temperature.vi |
Solved! Go to Solution.
08-31-2011 07:30 AM
Please describe further. What file? What process are you referring to? App builder/installer or the LV environment?
08-31-2011 08:12 AM
I'm mass compiling my project.
One of lines is like that.
I'm asking generaly what could be the reason of skipping. What I'm expecting is only 'Bad VI' or 'Compiled'.
08-31-2011 08:23 AM - edited 08-31-2011 08:24 AM
That message is given when the file isn't actually a VI, even though it has a .vi extension. Can you actually open that specific file in LabVIEW?
Did you get that instrument driver from the NI Instrument Driver Network? If so, what is the exact link where you downloaded it from?
08-31-2011 08:27 AM
OK.
There no file at that location.
How I can get know which VIs from my project that VI is called? I'd like to re-link the VI to the proper location.
K.
08-31-2011 08:29 AM - edited 08-31-2011 08:31 AM
Just open your top-level VI. Follow the error messages.
Since it's an example VI it's highly unlikely that any VI is calling it. You probably just have it in your project file and then deleted it from the file system. In this case the project should at least show a "Warning: File missing" next to the name.
