Sizing numerical arrays to other string arrays
I want the Voltage a6 a7 columns/array to match the size of all the others for alignment purposes. I have to shrink the text too much to accomplish it. Any ideas?
(1,018 Views)
Accepted by RHutchings
Replace the numeric element with one from the "Modern" palette. Silver has a lot of border spacing.
(1,014 Views)
Thank you very much.
(1,003 Views)
Unless you really need them, I would also hide the increment/decrement of the "# BYTES" and "RELAY BANK" so all numeric fields have the same height and font size.
Is this really a control where the user can change things or mostly an indicator. As indicator, maybe the entire thing could be done with a table. If some of it should be a control, consider voting for this idea. Now you could make each row a horizontal cluster control (with fields acting as indicators disabled) and make a vertical 1D array of these clusters.
(975 Views)
Most of this needs to be changed on the fly including Bytes and Relay Bank. Only D2-D3 and Voltages are indicators only.
I would love to change this to a cluster, I already tried it, but there are a lot of behind the scenes reading and writing to Excel. This works for me so I'm not going to rewrite it.
(968 Views)
