10-03-2012 11:42 AM
Hi guys, I am conducting my application which need a single phase grid-tie inverter. I want to find a custimized or commercialized single-phase grid-interactive inverter which allow the user to define the control algorithms. I wish I can controll this inverter on Real Time by my CRIO since I have already get these analog/digital I/O modules with my CRIO.
Do you guys any any recommendation for which inverter I can find to achieve this kind of function? or any other suggestion for my application.
BTW, I read there's some NI product called NI Single-Board RIO General Purpose Inverter Controller. Is that one have some specific function for inverter which CRIO doesn't have or it is just a single-board RIO which has similar function with a normal CRIO?
Peter
10-03-2012 01:16 PM
10-03-2012 02:02 PM
Peter,
1. Does anyone make a single phase grid-tied inverter? Except for the HVDC lines, all power grids are three phase. Connecting a single phase inverter to the grid would tend to unbalance the grid. Most likely your electric company will not allow you to connect a single phase inverter to the grid.
2. There was some mention of the Inverter Controller at NI Week. Perhaps you can find something in the on-line (but not grid-tied) NIWeek information.
Lynn
10-04-2012 03:10 PM
Hello sdualienware,
The functionality of the Single-Board General-Purpose Inverter Controller (GPIC) is defined by the code deployed to the hardware and may in fact, be used with a normal CompactRIO. I have included a few helpful links below that will not only help to explain the functionality and benefits of using the NI-RIO technology to perform this control (although most resources specifically point to the Single-Board RIO), but also provide sample code that may be used for single-phase inverter control.
http://www.ni.com/white-paper/14207/en (NI Single-Board RIO General-Purpose Inverter Controller)
https://lumen.ni.com/nicif/us/codepowelecguide/content.xhtml (Download the Latest Power Electronics Design Guide Code)
https://decibel.ni.com/content/groups/power-electronics-development-center (Community: Power Electronics Development Center)
10-05-2012 11:21 AM
Hi johnsold,
There are indeed some grid-tie single-phase inverters in the market. As long as the inverter manufacturer follow the UL 1741, IEEE Sta 1547 and the related rules in your state. It is legal to use such kind of inverters. However, my problem is most of them are commercialized model, which means it's difficult for me to apply external control to them. What I want is to find a inverter which I can apply my control based on the communication with compactRIO.
Thanks for reply.
Peter
10-05-2012 11:22 AM
Hi GerdW,
Good idea. I will try to call them for suggestion. Should I call the local NI's support or I should creat service request online?
Peter
10-05-2012 11:29 AM
Hi WesWNI
Thanks for providing these information. Do you have any suggestion for the related hardware selection? I don't want to build the whole inverter by myself so I am seeking a inverter which I can applied control with the CompactRIO. Or if possible, may I call you or email you to discuss this problem so I may give you a more detailed description for my need.
Peter
10-05-2012 12:14 PM
Hello sdualienware,
You may contact your Account Representative by calling (888) 280-7645 who will be able to assist you further in configuring a system capable of meeting the requirements of your application. While speaking with your representative, you may also ask to have your local Field Engineer contact you either by phone or in person to discuss your application in greater detail.
