I have Labview 5.1 and a NI 6602 counter/timer card. I need to start, make several readings, and stop 4 counters simultaneously (ttl pulse input). It is critical that they all be started and the final reading taken at the same time. I have tried several of the simple VIs and example codes but I am new to counter programming and don't know enough to make them work. If someone could provide information/explanation or example code, it would be most helpful.
Ron
