09-29-2011 07:45 AM
No, I am not running Matlab during the installation.
Anyway, I believe I found the problem: I am installing Simulink Interface Toolkit (SIT) 2011, whereas I am running LabVIEW 2010 SP1.
I could not find SIT 2010.
Thank you
09-29-2011 07:51 AM
Ok good to hear. I hope it all works ok for you now. If you have any more queries don't hesitate to let me know.
09-29-2011 08:05 AM
Well, actually it does not work... I cannot find SIT and Matlab Support 2010 anyware.
Matlab support is not included in the installation DVD, at least not in the Accademic License version.
09-30-2011 03:05 AM
Hi Tommpogg,
I have spent some time searching and found some information on how to establish the connection to the SIT server. A startup.m file needs to be created in the location:
C:\Program Files\MATLAB(your version)\
The following lines need to be in the startup.m file:
addpath('C:\SimulationInterfaceToolkit\ModelInterface\tmw');
addpath('C:\SimulationInterfaceToolkit\UserInterface');
addpath('C:\SimulationInterfaceToolkit\lib');
NISITServer;
When you open up MATLAB, the startup.m file may open but if not you can run it after it opens, you should as a result connect to the SIT server and be able to place the NI Signal Probe.
I hope this helps, let me know the result.
