09-22-2013 12:14 AM
I should use counter and count the number of rising edges in a loop to calculate frequency . The input signal will be connected to PFI lines of DAQ 3636 OEM. but the problem is I don't have aceess to hardware.
Could you please let me know how can I simulate this process so I can generate a pulse and count the number of rising edges and then calculate frequency without hardware.
09-22-2013 06:51 AM
The hardware simulation mode does not allow for this. If temporary, you can place a random number generator where the DAQmx Read is. How long before you get the actual hardware?
For a frequency measurement, you would not count pulses and calculate. You would simply perform a frequency measurement directly.
09-22-2013 06:52 AM
Two options-
1.Check out the waveform generation functions, generate a square or pulse train and pass to your function.
2.Go into NI Max and create a virtual card to feed simulated data to your application. I'm not sure what waveform options will be available, but it will only take a short time to create a virtual device and see what waveforms it has in Max.
09-22-2013 07:05 AM
1. You cannot pass simulated waveforms to a DAQmx function - the counter read.
2. A virtual card cannot feed virtual waveforms to anything (virtual or real).
09-22-2013 11:03 AM
My bad- assumed he was acquiring a waveform then doing measurements in software.
