Simulate a lower ADC resolution
Hi all,
I am working with the NI 9235 strain gauge module, which has a 24bit ADC resolution. This is great for bench testing, but in the end application I will probably use an embedded system with a lower input resolution. Is there a way that I can simulate a 10bit or 16bit ADC by disregarding the additional 14 or 8 bits in LabVIEW?
Thanks!
Andrew
(2,690 Views)
If you have the raw ADC data as an integer, simply drop the logical shift primitive (quick drop type "Logical Shift"). Wire your ADC codes to the "X" input, create a constant on the "Y" input and set that constant to -14 or -8. The output will be now be 10 or 16 bits. However, this will be an EXTREMELY accurate 10/16bit A/D, you may wish to randomize noise onto it if you are trying to simulate a system.
Charles Chickering
Architecture is art with rules.
...and the rules are more like guidelines
(2,659 Views)
