03-15-2017 09:42 AM
03-15-2017 09:51 AM - edited 03-15-2017 09:53 AM
I hope I did it correct.
Thanks for keeping up with me.
03-15-2017 10:02 AM - edited 03-15-2017 10:02 AM
Hi Xebe,
wow, you did it the "hard" way using the simulation toolkit. (I don't have this toolkit installed and so cannot run your VI.)
I was talking about the PID toolkit, available for free with recent LabVIEW versions (atleast better than Base version)!
03-15-2017 10:55 AM - edited 03-15-2017 11:03 AM
So you just mean the PID block?
I'll try to use that one instead and keep you updated
Edit: Something more like this (attachment)
03-15-2017 12:11 PM - edited 03-15-2017 12:12 PM
Hi Xebe,
I simplified your VI even more!
Keep in mind: this simple VI does not include any "plant simulation", so the PID controller has no chance to ever reach its setpoint as the "control system" does not react on the PID output signal…
In the example finder you will find VIs demonstrating PID with some plant simulation included!
03-16-2017 04:45 AM
Thanks a lot, this was very helpful.
Do you perhaps know if there's a way so that the PID only works when the PV goes outside the set limits?
03-16-2017 05:05 AM - edited 03-16-2017 05:18 AM
Hi Xebe,
With "real" PID controllers (available as hardware block) you most often have a deadband setting which exactly does what you request now.
You can fake this in LabVIEW quite easily:
IF ABS(pv-sp) <= deadband/2 THEN pv:=sp ENDIF output := PID(pv, sp)
You find other threads on this topic in the forum…
03-16-2017 05:41 AM - edited 03-16-2017 05:52 AM
where exactly would i put in this code?
And where do i fill in my high and low value between which it doesn't have to work? (I have little basic knowledge about code write programming)
Edit:
Found out a solution for the problem that seems to work.
Thanks a lot for your help and patience with me.
