Simple VI to use NI 8451 to write and read command
Hi, I am using NI 8451 to communicate with a device over I2C. Can someone help me to create a simple VI In which I can send the command and in return I should read the following. ( I am new to Labview).
Read output raw data:
S B0h w 0x1C 0x0B P
S B0h r Vout_12VL Vout_12VH Vout_5VH Vout_5VL XX XX XX XX XX XX PEC   (total report data is 10 bytes)
this is the example I got from the other thread. but I am unable to send 0x1C and 0x0B together.
I am able to communicate with the device after converting the 8 bit slave address to 7 bit.
Message 1 of 1
(435 Views)
