Shrink .hws files
I am have the problem that the hws file i created is too large for my NI-PXI 5422 card (32MB). It's about 1MB too much. Is there a possibility of reducing the file size? The file just produce a single cycle 11.244kHz signal.
(2,154 Views)
 Hey,
i think it isn´t able to reduce the file size. How about to take a lower sampling rate in order that the filesize is smaller?
By the way how do you generate the Signal?
regards
Patrik
(2,100 Views)
The signal was generated with the Analog Waveform Editor from National Instryments. I'll try doing it with a lower sampling rate. Right now it is 200MS/s.
(2,084 Views)
