03-29-2012 08:47 AM
Is it possible to show the maximum index number with value "true", like shown underneath?
I can show the value on what index the series of "true" ends with the "Array Max & Min" function, but when there is
one False between those True's, it will show the index of the True left of the False.
I don't need to know the size of the array, because it has to stay 8
File is attached
Solved! Go to Solution.
03-29-2012 08:55 AM
03-29-2012 09:04 AM
Thank you so much for the fast and perfect response !!! Kudos are well earned 😉
