Reply
Shortcut of FrontPanel doesn't work
Highlighted
I'am french user, using Labview 8.
I have a Main VI wich contain FrontPanels. I don't have any trouble to load subVI in the front panel component, every is all right, but the shortcut on the button of the subVI doesn't work in the FrontPanel. Is there a solution of this probleme ?
Thanks.
(767 Views)
Described like this it is hard to find the solution... could you describe how, when and why the FP of your subVI shows up ?
Maybe you can post a part of your code or a screenshot Smiley Surprised.
Tryin' to help...
Epictetus
Antoine Chalons
(767 Views)
As you can see in the picture, the subVI is loaded in the Front Panel, but when I press shortcut F1 nothing append, it doesn't action the button "Forcer [F1]"
(759 Views)
Ok, so you just display the FP of your subVI in the FP of the main VI, if this is correct then I'm not sure that the keyboard shorcut can work... what you do as a workaround is place an event in the main vi to detect when F1 is pressed.
Epictetus
Antoine Chalons
(753 Views)
