Sharing a VISA refnum between two while loops.
I think this would be the most suitable solution since you only call the visa read / write once at a time, keeping all data buffered and using notifiers. Thanks everyone.
Message 11 of 26
(2,450 Views)
that's even easierMain loopsMain loops
SubVISubVI
Labview 4.0, 5.0, 6.1, 8.6, 2009, 2011, 2012, 2014
If you do not know something, ask me.
Message 12 of 26
(2,446 Views)
By the way, in the settings of the port (control panel) I recommend setting the size of the receiving fifo buffer equal to 1. Thus, pauses between sending from ~ 50 ms to 3-5 ms decrease. This is due to the fact that the timeout for filling the buffer of the receiving chip is minimized.
Message 13 of 26
(2,444 Views)
SubVISubVI
Hi Borjomy,
Have you seen my Nugget on Action Engines found here?
I ask because your suggestion is very close to the form of an Action Engine but requires the assistance of the seq frames to make it work right. Action Engines can offer a an approach that is just a little bit cleaner and easier to use.
Just trying to help,
Ben
Message 14 of 26
(2,423 Views)
Hi, Ben
Sequence is used here only to press the "Stop" button after stopping all cycles.
Message 15 of 26
(2,409 Views)
@Borjomy wrote:
Hi, Ben
...and ensure the session is not closed prematurely.
Ben
Message 16 of 26
(2,406 Views)
@Ben wrote:
SubVISubVI
Hi Borjomy,
Ben
In fact, if I fully impemented the design I started, I would take that 1 step farther than AE and write a library with an AE as a private vi with Init, Close, Set, and Query actions and VISA Session on th Shift Register or FeedBack Node, Wrap those actions in public subvis with standard error handling and call it a "Resource Module" Operating on the VISA Resource.
"Should be" isn't "Is" -Jay
Message 17 of 26
(2,385 Views)
@JÞB wrote:
...Ben
If any of you are not familiar with Libraries as Jeff mentioned...
See this blog where I shared a Nugget on how to exploit Libraries in LabVIEW.
Note: Signing up for that blog will only get you updates if and when we post more nuggets. Smiley Wink
Ben
Message 18 of 26
(2,379 Views)
If the project is small, then it makes no sense to equip the library. This is an extra work. The main thing is that the exchange with devices connected to one VISA device should be done in one VI
Message 19 of 26
(2,370 Views)
All projects start small. What Jeff was suggesting is a Best Practice that I agree with strongly.
Thank you,
Ben
Message 20 of 26
(2,362 Views)
