05-30-2016 03:34 PM
Does anyone know if using shared variables in LabVIEW are supported for OPC UA?
Or should we use the OPC UA API?
Labview 2013 is used with DSC module, connected to a Kepware OPC UA server (located on the same PC).
Thanks in advance!
05-30-2016 03:42 PM
If you're talking about OPC I/O servers then those are DA only so you will either have to use the API or have a DA server connect as a UA client to act as a repeater.
05-30-2016 03:58 PM
