12-11-2017 02:12 AM
I am using a stacked plot (chart) for presenting incoming experimental and predicted data. I would like to group multiple plots within one panel. Say I have 4 sets of data (2 x experimental + 2 x predicted). In a stacked plot LV automatically creates 4 panels. However, I would like to have only two panels, each showing 1 experimental and 1 predicted data set. Is that possible?
Thanks!
Ture
12-11-2017 02:23 AM
12-11-2017 04:43 AM
Thanks for the quick answer.
That is too bad. I do like stacked plots because they are very compact and all panels share one common x-axis, which makes life in some cases easier (e.g. when programmatically clearing the charts).
12-11-2017 05:25 AM
Hi Ture,
You can hide all unneeded things for 2nd chart…
Hide the x axis and set it using property nodes.
React on events of the 1st chart…
