05-07-2013 04:27 PM - edited 05-07-2013 04:28 PM
Hi everyone
Here is my question: currently I have 4 separate waveform charts having the same x-axis (current date and time).
What I want to do is to plot these 4 waveform charts one above the other with only a single x-axis at the bottom, is it possible?
I don't want the 4 curves on the same chart.
Thank you in advance for your replies and have a nice day!
Solved! Go to Solution.
05-07-2013 04:54 PM
Have you tried to wire a 4 element cluster to the y axis of the chart?
05-07-2013 09:23 PM - edited 05-07-2013 09:26 PM
make an array of waveforms of it and try the mixed signal graph
right click in the plot area and add plot areas
you can distribute the plots on the graphs via drag and drop at the legend or by property notes
05-07-2013 09:51 PM
maybe this will help...
05-08-2013 05:07 AM
Hi Rafale,
You can just bundle the signals with a bundle function like this:
On the front panel, right click the chart and select stack plots. The multiple plots in the chart will now be shown in multiple plot area's within the same chart with only one X-axis.
Let me know if this is what you mean and wheter you have any questions left.
05-08-2013 06:07 AM - edited 05-08-2013 06:08 AM
Hi Rafele,
Little addition to my previous post. See the solutions for a waveform datatype below:
The build array function needs to be set to concetenate inputs.
05-08-2013 09:03 AM
Thank you for your answers!
Problem solved!
05-08-2013 09:06 AM
Any time! Good luck with the rest of your application.
