11-21-2016 06:33 PM
My main concern is VISA configuration. I am able to send a string, but it seems there is no return string in this case a respond. What I am sending can be referenced in Pg 14 from the attachmnet below.
11-22-2016 05:51 PM
Hi jp978,
Do you know if your device is able to communicate properly with VISA? Have you tried and established this with a more simple case?
11-22-2016 05:58 PM
I have looked at some of the examples, but dont quite know how to apply a simple test to this RFID reader. I don't think the manual provides a test case either.
11-23-2016 09:50 AM
Hi jp978,
I understand how this can be frustrating and I commend you for your effort! My recommendation for a best first step in troubleshooting would be the need to ensure that a proper connection has been established and that your device is communicating properly with VISA via *IDN or some other method of communication being that the application is not functioning as expected. Once you know that the device is communicating as expected with your computer then I would recommend trying to apply a simple test to the RFID reader.
I hope this helps!
11-26-2016 08:41 PM - edited 11-26-2016 08:42 PM
Quick Update:
I managed to get correct readings from the tags. I verified the EPC with the UHFreaderDemo provided by the manufacturer.
I will also post my code for anyone that may want to take a look, as soon as possible. In my case I only wanted to run an inventory command and read tags within range.
Thank you guys for the suggestions and help.
