11-05-2018 11:19 AM
How do I change the webVI HTML to set e.g. the LED in a datagrid control. True is green and False is red. Below is the default definition.
jqx-led[ni-control-id='25'] { font-size: 12px; font-family: Segoe UI, Frutiger, Frutiger Linotype, Dejavu Sans, Helvetica Neue, Arial, sans-serif; font-style: normal; font-weight: normal; text-decoration: none; --ni-content-display: none; --ni-true-foreground-color: rgba(255, 255, 255, 1); --ni-false-foreground-color: rgba(43, 48, 51, 1);
11-08-2018 10:47 AM
Hi André,
From the looks of it the color is given as an RGB triplet and so for red and green for true and false you would make the following changes:
--ni-true-foreground-color: rgba(0, 255, 0, 1); --ni-false-foreground-color: rgba(255, 0, 0, 1);
Hope this helps!
Mitch
11-08-2018 10:54 AM
Hi Mitch,
I've tried it, but the declaration is in the auto-generated section.
I've also tried to put a copy in a user-defined style section, but that doesn't override to prior declaration in the auto-generated part.
In addition there seems to be a single declaration for type LED, so I would also like to know how set properties for different LED instance on a webVIs FP.
