03-29-2006 11:52 AM
03-29-2006 03:06 PM
03-29-2006 03:50 PM
03-30-2006 02:11 PM
03-31-2006 03:10 PM
03-31-2006 04:49 PM
Hello Micaela,
What DAQ board are you using in conjunction with your SC-2345?
I am using a PCI-6221 card.
Are you just testing your temperature in MAX using the test panels or are you using some other program?
I wrote a small VI with a DAQmx Read block that puts the data into a waveform chart. I have also tried the test panel in MAX.
Have you tried to measure just a simple voltage to verify that your DAQ board is functioning properly?
No I have not. This setup is maybe 2 months old at most.
You had asked in one of your previous post about what the CJC Value should be when you have the CJC source as constant. From the Context Help in LabVIEW and Measurement and Automation Explorer (Ctrl-H) - the CJC Value is the temperature of the cold junction of the thermocouple when CJC Source is set to Constant. The temperature value uses the same units as Input Range.
How do I measure the CJC temperature on the TC02 module so I can use it as a constant? I found a VI called Acq CJC Temperature.vi in the examples section, but it will only measure Dev1/boardTempsensor_vs_aignd. I think that is the temp of the PCI-6221 card and not the TC02 module.
Am I correct in that I must use a constant CJC value insted of the built in CJC source? (Since I am using the uncompensated panelette)
I would also try Conseils' suggestion of connecting the ground the SC-TC02 to the SC-2345 ground after verifying that your DAQ board is functioning properly.
I can give it a try. But it goes back to the question of do I need to use a constant or can I use the built in CJC source?
Bryan
04-03-2006 12:14 PM
04-03-2006 12:19 PM
Hello Micaela,
I like that idea. Should I use extension wire? Or will regular type T wire work for this?
Thank you,
Bryan
04-03-2006 12:41 PM
04-03-2006 01:55 PM
